Battery Problem
Discussion in 'Sportster Models' started by cedarbrook63, Mar 6, 2010.
  1. cedarbrook63
    cedarbrook63 Junior Member
    794
    Hi folks. I'm a bit puzzled about my battery.
    I have a Sporty with about 1700 on the clock. I keep it attached to an Optimate 4 tender when I'm not riding it - apart from a 3 week period about a month ago which it spent at my dealership having the 1200 conversion done I while I was away. I rode it very little up to this week because of bad weather and salted roads - I just did the 30-60 break in.
    I've put two different battery chargers on to the battery and both are going into "Recovery" mode trying to restore it from being sulphonated. I took her out for a good ride with Hobbit and a few friends on Wednesday and she ran well but I have noticed a moment's hesitation before the engine turns over on pressing the start button.
    I've checked the battery with a voltmeter and it's reading about 12.7-12.9.
    It displays high 13s when the engine is running.
    I don't know why the battery has gotten into such a poor state if the tenders are reading true. I don't know what else I could be doing to keep it in good order.:newsmile030:
    Any thoughts or advice. Thanks guys.
  2. NEWHD74FAN
    8,191
    98
    19
    Battery sulfation is when deep discharge has occured and salts settle out of the electrolyte, fall to the bottom and turn into a conductive slurry, eventually shorting out a cell (battery will read less 2V for every on shorted). That said, did you read the voltage at the tender attached...should read 13.8V or so as well. Battery tenders use logic and voltage window comparator circuit to manage charge.
  3. Breeze3at
    Breeze3at Well-Known Member
    4,922
    224
    It could be the brand new pistons & rings and 300 more cc's generating a bit more strain on the starting system. I'd suggest breaking it in and see what happens. It might just be different than what your used to.
  4. fin_676
    5,776
    153
    284
    Could just be that there is a wee bit of corrosion on the ends of the battery cables you need to take them off and clean them at both ends to ensure a good connection
    even if the battery is good the power dont flow through if there is a restriction somewhere
  5. cedarbrook63
    794
    I'll have them off tomorrow and clean the connections. My dealership suggest they will link it to a car battery charger for a short burst next week if I leave the bike with them but I've read somewhere that that can damage the plates. If there is a problem with the battery, I don't know where it's arisen from - it's literally had all the tender loving care I could've given it lol.
  6. Chopper
    Chopper Senior Member
    1,632
    19
    12.8 is what a brand new battery should be reading, could be everything is still really tight from the conversion still and cleanning all the terms like Brian said is always a good thing. Colder weather and a higher compression could affect it also if you have ether.
  7. fin_676
    5,776
    153
    284
    Hooking up to a car battery charger may put too much amps in and warp the plates the optimate is a much better charger for the motorcycle battery
    but also you may have a little more compression than you had before the 1200 upgrade and this will be harder on the battery and starter but any drop in power flow from battery to starter will show more when it needs more
    so start simple and work to complicated and get the cable ends cleaned first
  8. cedarbrook63
    794
    Thanks guys. I'll try that first and see what happens. I had read on this site about the risks of jump starting from a car and thought the same even moreso may apply from a car battery charger.
  9. NEWHD74FAN
    8,191
    98
    19
    You are correct, car battery chargers are basically "low tech", step down transformer (converts 120/230VAC to 14-16VAC or so) followed by bridge rectifier (diodes)...and some sort of thermal protection...DONE.
    What this means is no control logic to taper charge once battery is up and no regulation (other than maximum rating for voltage and current) which can "boil" off what little electrolyte/gel moisture that may be present, weakening bonding of the plate materials, and destroy the battery if left on too long. A "Rule of thumb" is 1/10 of CCA for for no more than 1 hour...followed by proper battery tender trickle for the balance.
  10. cedarbrook63
    794
    Thanks R. Cleaning the terminals and connectors made no difference so I'm going to let the dealership have it this week as that's the only way I can get it established that the battery is a goner and should be replaced by them. Worst case scenario is that they bring it back to some sort of health for a while but I presume all those sulphates don't just go away, they'll just sit on the bottom. In that case I think I'll just buy a new battery. I don't want a dodgy battery hanging over the start of my season.
