Well, all my stuff is Craftsman and I have a gas trimmer it just doesn't start as easy as I'd like. What started all this is my Brother said his was useful. Some how I never got the brand name, but will check into it. Thanks to all for lending a thought.Have to say I used to get the cheap/WalMart electric trimmers & over a few years of them losing power & breaking I knew it was $$$ well spent to invest in decent gas trimmer. Got a Echo (Home Depot sells them) and after 7-years of use it still chews grass like a band of crazy sheep. Definitely look into the cost of gas vs. electric & you'll see it's a tad more, but cheaper in long run and...no need to recharge, or drag cords...
Much as I hate to say this, you can find all your major brands @ Sears now, including Black and Decker, Register for shop your way rewards then you will get discounts, They are ANGRY @ me now and I am having a hard time finding info on friends and family nights but I will continue to check:sI have a Black and Decker 18 volt trimmer. I actually like the little thing. It does work better than I expected.
I have 1/2 an acre fully grassed and I use it to trim the edges, around the walkways and septic lids.
The head can rotate 90 degrees so you can vertically trim walkway edges etc.
It works fine for what I use it for. I paid around $60 for it.
If you need a weed whacker, don't buy one. It works great for my purposes but it will not cut down heavy weeds.
I also bought an extra battery in case it takes longer than expected.
I can usually do the entire yard on one battery.
The extra line spools are cheap and very easy to replace. They just pop in.
One thing I do not miss is mixing gas, pouring and spilling gas and coming in from outside smelling like exhaust fumes when I am done.
Black and Decker also makes a 24 volt model but it is more expensive.
I would go with a gas powered unit. Cheaper and easier to modify all the way through Stage 4. I don't know if Dobeck has any fuelers for them yet.
