battery not charging
Discussion in 'Electrical' started by chris dillard, Aug 5, 2012.
  1. chris dillard
    chris dillard Member
    19
    2004 roadking, bike would't start,figured battery,replaced battery,one week later same problem,read all the tips on line,everything pointed to regulator,changed reg. same problem battery not charging,here is what i have
    unpluged harness from reg to stator
    on plug going to stator checked pins to ground ok no ohms
    checked pin to pin 0.01 ohms
    26 volts ac at idle goes up with throttle
    is it possible that the reg i bought is bad,is there something else that can be draining power.....help at the end of the road
  2. 90FXRS
    90FXRS Junior Member Contributor
    458
    10
    Is it logging any DTC errors? I'm wondering if you pull the primary inspection cover is the fluid black and smell burnt? If so it's probably the stator is toast. There are some good reads and info in the self-help section concerning diagnosing different areas of the charging system.
  3. TQuentin1
    4,737
    142
    Have you done the easy stuff like checking the battery cable connections at both ends? In fact, I suggest removing both cable ends, wire brushing them and reinstalling. For both cables.
    Then give the primary fluid a sniff test. If it smells burnt, then the stator is probably toast, even if it is putting out Vac appropriately under no load conditions.
    The sniff test is not definitive, but if the fluid smells bad (burnt) it is pretty likely the stator.
    You can have a bad VR even if new. Is your system a three phase or single phase?
    There should be test instructions for both in the self help area. Additionally, Hoople should be on shortly to give you some pointers on testing the VR or other tricks to check out the charging system.
  4. Dr. Dolittle
    6,404
    118
    29
  5. chris dillard
    19
    cleaned all post and cable ends,fluid doesn't smell crapy,can a bleed test be run on the reg. some articles states that cant be done, if i check voltage at plug on reg i get 12+ volts on each pin ..where stator plugs in
  6. texas tom
    texas tom Active Member
    131
    The regulator is just a bunch of diodes,they are one way devices you should have 26vac at stator at idle,at the battery you hould read +13.76vdc or so with a fully charged battery at idle.If you have the correct voltage at battery at idle there is nothing wrong with the charging system you have a drain on battery.If you only see +12vdc at battery your charging system is not working,and or you have a wiring problem between regulator and battery.At the left side of reg is output to battery it should be +13.76vdc or so.good luck..
  7. Hoople
    Hoople Account Removed
    7,198
    34
    Are you sure about that? What range did you have the meter on. Was the meter on auto range? If so set it on a fixed 200 ohm range. Not that it changes anything, but that number you read is really too low.
    When you say "goes up with throttle",,, goes up to what? 1000 RPM =? 2000=? 3000=?
  8. chris dillard
    19
    can a bleed test be done on the regulator,some articles on here states that it cant be done,when i remove plug from stator at reg. and check the terminals i get 12+ volts on each one, does that mean reg is shot...this is with engine and switch off
  9. chris dillard
    19
    26 volts ac coming from stator,reving engine volts go higher
  10. Hoople
    7,198
    34
    Changed regulator with what? A brand new Genuine HD? Brand new aftermarket? Something used?
