Hoople
Account Removed
15v at the battery for a few seconds and then 4.5v
(I am guessing they were generators back in 1986)
4 and 1/2 volts at the battery? Are you sure about that?
Gentlemen Thank you for your input and advice. I found that the wire going to the battery had a break in it inside the covering and only found it by moving it while running a continuity test through it...man that was a brain-ache. Charging at 13.6v at idle and 15v at 2000 rpm, so it looks like the problem is solved. Going to do a complete rewire when I can take the old girl off the road. thanks again guys
