free website stats program Average cost to replace fuel pump? | Page 2 | Harley Davidson Forums
none of the fuses appeared to be bad but we changed them all anyway. the fuel pump came on the first time we tried after changing all the fuses and putting in new battery, but now the fuel pump does not come on. The bike cranks and is definately getting power, but like it is not getting gas to keep it going. other than fuses, what should we check next?
Well pull the fuse for the pump, and using your DVOM, see if you have voltage across the fuse plugs. If so, you can pull the fuel pump assembly out of the tank, unplug the wires and jumper to the battery or another 12Vdc source to see if the pump is working. That will determine if you need to replace it, or if it is wiring/connections from the pump back to the fuse block. If the latter, it is a tracing exercise to figure out where the break is.
...If somehow it is your fuel pump, that is a pretty easy replacement. Just have to get to the cover plate, remove the 10 or so screws holding that down, and the unhinge the pump assy so that you can remove it more easily...
REmember to order new "sealing screws" for the cover plate. They are single-use screws with a sealing function. Many for get this detail...
Enjoy,
Rich P
