Good thing you checked, alway's a good idea to check it yourself after works been done.
I checked my '07 Ultra service manual and the 45 ounces figure is for a dry fill. When the primary is taken apart and the reassembled. All the fluids would be wiped clean.I went in and talked to the service manager and I was polite and calm. I did point out the amount of oil that was recovered and he claimed that not all the oil comes out of the primary when doing a oil change, then I pointed out that when the primary cover is removed it is required to put in 45 fluid oz of oil, so if I was just doing a oil change in the primary I should of recovered 36oz of oil not 26 oz. I also mentioned that there was no excuse for the clutch to be that far out of adjustment.
Wacko....
Lonely feeling, getting a raw deal as you did. They were going to have to put the tires back on anyway. Then they blamed the extra charge on the "computer."
I was one of the lucky owners with my 2001 Toyota Tacoma.
In for an oil change and they called, said my frame was rusty and I qualified for a new frame. FREE!
1995.5-2004 Tacomas had a rust problem. The American company that stamped out the frames didn't do a proper rust-proofing, Toyota didn't catch it so if the frame has any perforation, they replace the frames (2001-2004) or buy-back (1995.5-2000) the truck @1.5 KBB, excellent condition. You can be hauling wood, it's still considered excellent condition for the buy-back.
Replaced the frame, rear springs, lower control arms, brake lines w/e-brake cable, hardware, recharge A/C, new anti-freeze, hardware and labor. All free!
My drive train was good, they lifted off the cab and box. Just slid the new frame under and rebuilt the frame.
Here is the common sense kicker that Midas should have done.
Because the old shocks were going to be placed back on the new frame, if I wanted new shocks, just buy them (any brand) and it would be free labor. The work operation was easier for the mechanic. Same job, old or new shocks. It was easier for him because he didn't have to take the old shocks off.
Same deal with exhaust. Same work operation labor wise.
They treated me right! Already had a new Toyota exhaust but I did buy new Toyota shocks. Toyota has a deal. Buy Toyota replacement shocks and/or exhaust, after that it becomes life-time free parts and labor if needed again.
The tires were already off at Midas. What difference would it have been to roll them to another wheel?
They took advantage of the moment and lost a customer. Maybe more customers than just yourself.
Toyota treated me well. I didn't even know of the replacement program. It isn't a recall thing. It is handled differently.
They called me and said I qualified!
The bill sent to Toyota was between $11,000-$12,000.
Only thing I paid for was some new shocks and they discounted that price.
Oh by the way, when they put the tires back on the truck, they rotated them!
Customers remember when treated fairly and never forget when taken advantage of!
Probably the tech simply put in one quart in your primary when you drained it only 26 ozs came out time is money,but there is no excuse for the clutch being that way that is something that has to be exact for rideability purposes. When I fill my primary I dont measure the amount, I add until it just touches the bottom of the clutch basket that normally on a wet change is 32-36 ozs.When I have new tires put on my bike the shop will let me know if there is anything else wrong,last tire change they put new brake pads in the rear all I pay for is parts tire is already off,they have a customer in me for life..
Took the bike to HD dealer on 1/31/12 for a stator repair because I have the ESP. Sense then I felt a occasional clunk on the left floorboard so I decided to check the clutch adjustment. Well the clutch adjustment screw was turn out over 2 full turns when it was only suppose to be turned out 1/2 to 1 turn max. So I decided to change the oil so I would be sure that the required 36 oz of oil was in the primary, I only recovered 26 oz of oil from the primary. I guess the HD repair tech just doesn't know how to read a repair manual.
