Hoople
Account Removed
I am not saying your stator is bad & you should replace it but it is very difficult to determine if a stator is 100% good while it is still installed in the bike. Just a few shorted turns of wire can not be measured with a standard ohm meter. Even holding the stator in your hand has it's limitations. The magnet wire insulation is only a few thousands of an inch thick. Even performing a load test on the stator is not 100% proof positive. It throws the odds way in your favor, but nothing is a 100% sure thing when it comes to stators. Usually discoloration of a coil will give it away.
But there is a good side. A shorted voltage regulator will almost always take out a perfectly good stator. But a shorted stator has a very small chance of destroying a perfectly good voltage regulator. It is much more risky to only replace the stator and use the old VR. If you do, you must monitor the current draw of the stator when you start the engine.
There is much less risk in replacing just the VR while using the original stator.
All this applies mostly to single phase systems. It's different w/ 3 phase.
Changing the circuit breaker is good. At least there should not be too much of a voltage drop between the battery and alternator.
