I have a 2009. I am wanting to increase power (decrease 0-60 time).
what are REAL expectations of changing cams.
DO A TRUE STAGE ONE FIRST ::: A GOOD stage one WILL ENHANCE the performance of a SMALL cam... so no waste there.....
MY STAGE ONE :::
V&H slip-ons
scrm'n eagle air
DOBECKS TFI*** fuel management....
*** this unit enriches the TOO LEAN condition on ANY FI bike especially a harley, and will enhance performance with or without a stage one....
NOW if you haven't done the above, STAGE ONE,,,, TRY IT FIRST... It will produce a lot more power 0/120... and at affordable cost....
A low end cam WOULD have been my next step ,,,, BUT quite frankly I don't feel the need for it.. BECAUSE NOW my properly TUNED 2009 FLHR with STAGE ONE gives me PLENTY MORE power from 0/80 ... The TFI tuner did MOST of the power change.. NEW POWER........ THE kind you feel in the SEAT of your PANTS...
A CAM??? 26 andrews for more low end torque probably.... BUT like I said I am comfortable at this "stage one" for now....
I have had MANY hd's.... MOST ended up HOT... PLANNED AHEAD but A little here,,, then a little there ..... The HOTTEST was a 2000 dyna built to the HILT and PLANNED that way from the start....... Manley lrg. valves n springs SS570G,flowed n ported,95 cu in.. beefer support plate,lifters, fueling oil pump, Scrm'n eagle tuner, 42 mikuni... a LOT of other HOT stuff and 6 speed tranny,,,,,,,,, so I know a lot about 0 to 140 FAST.... and the $$$$$$$$$ that it takes to get there...
I'm SO satisfied with my new BIG BIKE and really don't need to build it into another MONSTER....
I USE ONLY THE BEST
REDLINE FULL SYNTHETICS
20/50 REDLINE in engine
MTL redline in chain-case
SHOCKPROOF HVGY. in tranny NEVER-EVER any metal on magnetic drain plug.....
