2007 FXSTC 96 WITH 67k--BROKE IN OR WORN OUT??
Discussion in 'Softail Models' started by bulldog10, May 24, 2014.
  1. bulldog10
    bulldog10 Member
    12
    Hi all--just getting back in after few years and a previous 91 FXRSP with 60k on it. Ran like a top.
    So bought the FXSTC with 60k on it. Seems to run well. Bit of top end chatter but remember that as a normal thing.
    How many miles would you expect this engine to have in it? At what point would you expect top end needs rebuilt? And any thing you'd expect as critical consideration at this mileage right away?
    Thanks!!!
  2. tourbox
    tourbox Senior Member
    1,902
    173
    If you are referring to the '07FX in your name I would think 100K, depending on how the previous owner/s had run it. At 60K I would check your Cam Chain tensioners. They are the new hydraulic type and don't wear as much as the old Spring type but I would check them anyway. If you don't have a service manual it would be a great investment. Also if you had any maintenance records for the bike.
    tourbox
  3. Jack Klarich
    Welcome to The Forum, Ray has you covered, A manual is your best fiend, you may want to check your clutch adjustment also
  4. bulldog10
    bulldog10 Member
    12
    100k you thinking top end rebuild? Bottom usually goes around what mileage?
  5. Jack Klarich
    Do a compression test first:s
  6. tourbox
    1,902
    173
    I would be hard pressed to guess on the bottom end. I'm in the process of replacing a crank assy. now, helping a friend. His was a 2000 or '02 Ultra with approx. 75K on it. The rear rod went South.
    The old rule of thumb for Shovels, and possibly Evo's, was rebuild both(top & bottom) on second top end.
    These TC's haven't been around as long as the Old stuff, including my Old self.
    tourbox
  7. Jennmarr
    Jennmarr Junior Member
    400
    6
    I'm riding an '07 Ultra with 128k on it. Bottom end is still going strong.
  8. tourbox
    1,902
    173
    Good to know on the bottom end Jennmarr. Have you had to do a top end yet?
    tourbox
  9. bulldog10
    bulldog10 Member
    12
    Thanks all for input!! It seems that bottom is pretty solid re reliability. Thoughts on top end appreciated. Not burning oil so it seems no issues for moment. Previous owner did keep records but mostly did own work per logs. Dealer suggested total fluid change service. $250!!! That typical??
    [​IMG]
  10. Dr. Dolittle
    6,404
    118
    29
    Yeah, typically outrageous! An experienced tech should be able to change all the fluids in under an hour. $250 is a total rip off if you ask me.
