2007 FLHX, 31,000 mlies and roaring
Discussion in 'Other Service and Maintenance' started by rotate, Aug 23, 2009.
  1. rotate
    rotate Member
    10
    It seems my bike is making a roaring noise at any speed. Clutch in or out, motor running or motor off, even in netural. I think it's comming from the trans or clutch. I can hear it if I roll the drive sprocket while the bike is on a stand with the rear tire off. so...... clutch or trans? I've been use SE oil and changing fluids every 5000 miles, just a few shards on the trans. mag. after the last oil change, nothing outragious. Oh yea it started the week after my warranty ran out!
  3. TQuentin1
    4,737
    142
    As Glider says, check the chain tension. Not sure if yours does, but if you have the auto chain adjuster, here is a tip that Glider posted in self-help:
    Automatic Chain Tensioner Adjustment - Harley Davidson Community
    If not, then it's the old-fashion way!!
    If that doesn't take care of it, suggest ruling out the compensator nut backing off by opening the primary and checking.
  4. glider
    Should be, it's an 07 with the self adjuster.
  5. rotate
    rotate Member
    10
    if the motor is off, the primary chain isn't moving...right?
  6. glider
    Motor off, nothing moves.
  7. rotate
    rotate Member
    10
    that's why i think it may be in trans or clutch hub bearings, it makes the roaring noise with the motor off. i guess i'm going to have to go into it.
  8. glider
    Hope you mean when you turn the wheel and not when it's parked on the stand :D
  9. rotate
    rotate Member
    10
  10. glider
    Can you isolate if it's the wheel, belt or trans?
