2003 road king breaking down at mid to upper throttle range
Discussion in 'Touring Models' started by pcseminole47, Mar 8, 2010.
  1. pcseminole47
    pcseminole47 Member
    15
    i have a 2003 rk at mid to upper throttle it starts breaking down and spitting and sputtering replaced the crankshaft sensor and the fuel line assembly but still having the same issue. i looked at the front injector wire it doesnt appear to be broken but im not sure if maybe it is an internal break as this is said to be a serious problem with this year model, anyone have an idea the closest dealer is over an hour away from here...only have 3000 miles on it
    Try wiggling the injector wire with the engine idling and see if you detect a stumble.
  3. pcseminole47
    pcseminole47 Member
    15
    ok ill do that
    So it is only breaking down under a load in gear in neutral it revs up with no mis fire at all...........
  4. glider
    Check/replace your plugs and or plug wires if they haven't been done recently.
  5. Chopper
    Chopper Senior Member
    1,632
    19
    Any trouble codes?
  6. shovelrider
    shovelrider Member
    We have seen a lot of internally broken injector wires here in Australia that is where I would look first.
  7. TQuentin1
    4,737
    142
  8. pcseminole47
    pcseminole47 Member
    15
    no dealer near here with a computer to check it for a code, checked inside the fuel tank no hissing or fuel spraying, tried to wiggle the front injector wire no change what puzzles me is it only acts up while driving about 20 mph in 1st gear 30 in second etc... max speed in 5th gear is about 53mph when it starts sputtering revs great in neutral......
  9. Chopper
    1,632
    19
  10. pcseminole47
    pcseminole47 Member
    15
    2003 rk rough running
    Still have a problem with my 03 rk checked fuel tank no leak checked front injector wires couldnt find a break i did trim it back and splice a new piece in checked both plugs and both are firing. Still breaking down at about mid throttle it seems to be about same area in the throttle in each gear and it seems that the exhaust in the left pipe is very cool compared to the right side need help.........
