That is how I adjusted the clutch. I am asking about the method that Glider speaks about in his (Easy Clutch Adjustment Method). Do you have an insight into that method or is it not used for my style and year of bike?
I think it feels like it is working. If I up shift it looks like it goes back to center postion, and when I down shift it looks like it goes goes back to the center position.Craig; Does your shift lever return spring feel like its working? If you lift up on the lever, can you feel the spring pushing down to its center position? When you push down, can you feel the lever pushing back up to its center position? Mid 90's transmission detent levers had sharp edges that wore into the spring and caused them to break.
