the guys at the shop are telling me my 2005 Sportster 1200 Custom only requires one quart of transmission/primary lube. is this correct? i ask because, after i put one qt. in, let it run, turn it off, and let it settle, i can take the little cover off, stick my finger in it as far down as i can reach and not feel ANY oil at all. is this normal? also, how do you know if it leaks out? there's no way to check it, at all?
thanks
ASKING is Fine,,,,, As you see you get The Answers...
TOTALLY NOT THE WAY TO CHECK THE LEVEL.(.)
May I suggest to get a BOOK (HD Manual) on the sporty....Look on E-bay or other to find the ORIGINAL Owners Guide that came with the bike,,,,, I assume You Don't have one or you wouldn't be asking
this question.... The Guide that came with your bike NEW would answer and allow you to CARE for the bike.. The HD BIG Manual book shows all about your model and Year sporty and HOW and NOT how to do things.. IT Is Worth the $$ to own one..
Both books would OF told you the amount and Type of Lube to use... On a sportster, The PRIMARY(clutch and tripple chain) and TRANNY are using a COMMON SHARED lubrication....
USUALLY Formal + from hd and YES 1 QT.
Books will tell you HOW and Where to look to see the Level of the oil in there...
IF BIKE DOESN'T LEAK ANY Tranny OIL,,,, Usually then,,, it only needs to be changed AT THE Suggested MILES/TIMES intervals Located in HD BOOK ...... Proper amount (1 Qt.) is all that is needed...
Get to KNOW your bike a little and you'll gain Much Knowledge JUST readiing Here on HDT.... BUT You gotta LEARN in my book,,,, FROM the book....
