I have about 5800 miles on my bike and it seems that the starter isn't engaging... I try to start it and I can just hear is whirling... I had to pop start her to get home today... If I his "start" while it's idling she will turn over on the next starting attempt, but won't engage if is doesn't start and I try to push the button again. I believe the starter drive/clutch is messed up (maybe) or the spring is sticking? It's over for the 5k service (because the 1k was a little late, so I figured I could have the starter repaired at the same time unless it's a pretty easy fix. I have build cars in the past, so I'm good with tools... I just don't feel like getting into an involved project with the bike I ride to work everyday. I have put about 3500miles on her in 3 months.
Any help would be great. I am new here, but did a search. Someone else had an issue that sounded the same, but I wanted to check to see if there was anything simple it may be.
