If front right only blinks when hazard warning lights are switched on then I would suspect wen you try right side on its own front right turn signal come on but does not blink dashboard light should also come on
That would suggest that there is a fault only on the rear right
Most likely cause of failure if bulb and housing are good is damage to the wires through the rear fender
The wiring runs under the rear fender and is held in place by metal tabs formed from the inner skin of the fender then goes through the fender the rear part of the frame and the cover that is over the frame and into the light unit so there are a few areas to check for wires that have been damaged by sharp edges vibration and debris
