medic80scott
please help i have a 02 sportster 883 and the right side turn signals not working. the front will blink but weak and brake lights working but nothing on the rear and nothing on the handle bars left side is working fine
your right the back right will not blink, right front seems to want to blink when to turn on the hazard lights. bulbs and fuses look goodI am a wee bit confused by the problem as normally there would be 1 turn signal on the front right side and 1 on the rear right side the front may be on the handlebars or the front forks but not both from your post that the front right is flashing dimly but nothing on the handlebars would suggest you have 2 turn signals on the front
Normally if 1 turn signal bulb is dead then the other on that side would come on but not flash as the turn signal module would not have sufficient power drawn by 1 bulb to make it flash
There must be some modifications made from stock to give the results you are currently having without knowledge of the modifications from stock will make it difficult for the forum members to give you suitable advice on how to troubleshoot the problem
Any further information about any modifications would be very helpful
