'02 Road King started backfiring
Discussion in 'Touring Models' started by tommytommi, Sep 4, 2009.
  1. tommytommi
    tommytommi Member
    15
    Riding home from work yesterday when I noticed the bike starting to backfire at 55 MPH. About 2 miles rom home it started doing it real bad and I barely got home. The bike is fuel injected and bone stock with 16K miles. Any thoughts?
  2. TQuentin1
    4,737
    142
    How much gas is in the tank? Did you just fill up? What was the last thing that happened before it started acting this way?
  3. glider
    Have you checked the plugs and plug wires to see if they are on tight?
  4. tommytommi
    tommytommi Member
    15
    Tank is 3/4 full. Nothing to indicate any problems other than the occasional fuel injector "pop" at start up. Indicates to me something Major happened.
    Plug wires appear to be fine.
  5. glider
  6. tommytommi
    tommytommi Member
    15
    Thanx, I'll have that done at Mel's Place in Boulder City.
  7. RedFLHRCI
    RedFLHRCI Member
    10
    Another possible problem with the early 2000's is the wire going to the front injector is sometimes a little too short. Over time the wire will come apart and you loose the front cylinder.
  8. tommytommi
    tommytommi Member
    15
    My mechanic told me to check my battery connection. Could be loose terminal causing the backfire. I'll check it when I get home.
  9. R. Lewis
    2,183
    5
    go ahead and take them off and wire brush-both ends of the cables and battery termn.,wipe off the old "dust" and tighten them back up anyway!
  10. tommytommi
    tommytommi Member
    15
    Terminals are good. Plug wires are good. When I turn the kill-switch on the fuel pump sound is more of a muffled sound than usual. I feel this may be the culprit.
