free website stats program Year Differences | Page 2 | Harley Davidson Forums
Year Differences
You got a point there and I'm going to tell you a secret if you promise not to tell anyone else......:s
I have to use the "search this category" at the top of each self help area sometimes to find the topic I am looking for. :lolrolling
No way you cant convince me, you have it all on your sleeve remember?:s
2007
* Updated 96 cu-in TC (longer stroke w/crank change. The big bore kit is now 103 cu-in)
* "Native metal" outer cam bearings and new roller chains.
* 6 speed transmission
* Harmon Kardon audio system w/80w per channel (optional)
* New material for saddle bags/tour pack
* All units are now fuel injected
2008
* Electronic throttle
* new 6 gallon fuel tank
* Harmon Kardon audio system w/80w per channel (now standard)
* Brembo 4 piston brakes
* ABS (optional)
* Quiet drive pulley on rear drive (IDS)
* Carbon fiber drive belt for longer life
* New adjustable fairing wind deflectors
* New intercom interface (console) on tank top
* New Induction Modules (no IAC)
* New and relocated ECM
* Frame changes including a new front engine mount and a relocated front stabilizer link
* New seat
* Late add - a rider activated rear cylinder cut out (RARCC) to lower heat in stop and go summer traffic
2009
* New stiffer combination stamped/cast frame instead of welded tubing
* New wider and stiffer rear swing arm
* New 17" front tire (130/80-17 Dunlop D407)
* New 16" rear tire (2" wider)
* IDS hub now integrated with rear wheel
* New suspension tuning
* New mounts for the saddle bags and tour pack increasing weight capacity ratings by 5lbs each
* Rerouted exhaust system to lower the heat on the rider/passenger (Note: the 'baby' pipe under the rear of the transmission may prevent the installation of an aftermarket centerstand).
* An additional added rubber engine mount (4 now).
* RARCC now standard (retrofit kit available for earlier models).
* New Tri-Glide Ultra Classic is a new trike straight from the factory w/103 cu-in engine for $29,999. $1,195 more for optional electric reverse on the tri-glide only
* Grease fitting on steering head is now more accessible.
