Wobble movement when I de-accelerate.
Discussion in 'Softail Models' started by tstock03, Mar 17, 2009.
  1. tstock03
    tstock03 New Member
    The last few time I got my 06 Deluxe out I noticed when I let off the gas I get a side to side wobbling movement from the front end. Does anyone know what could cause this? Initially I thought it could be the front tire unbalanced but if this movement only happens when I let off the gas… Any suggestions would be appreciated.
    It could be alignment, tire pressures, steering head adjustment , loose spokes and some other things. Best to attack them one at a time to find out what;s causing the wobble.
  3. jel123
    jel123 Active Member
    157
    First ck to make sure your motor mounds are tight,jel
  4. KingHeritage
    KingHeritage Junior Member
    472
    I would check tire pressure first
  5. STEVE07
    4,125
    68
    84
    Put it on a jack and spin the wheel by hand,sometimes you can see if it is the rim or a shifted tire
  6. Skratch
    Skratch Active Member
    399
    My Heritage did the same thing right around the 5000 mile checkup. They said the front end bearings needed adjustment and that was part of the maintenance. They did it and it worked wonderfully after that.
  7. hsjeff
    hsjeff New Member
    Spin the chrome cap off the main bolt for the triple tree and tighten it tighter than tight. That will solve it. Had same problem with my Heritage on a decell around 40mph.
  8. glider
    Make that 70 lbs TQ instead of tighter than tight.
  9. fatsteve
    fatsteve New Member
    check and see if the spokes are tight in the back wheel
  10. lamegame
    lamegame Member
    14
    +1 and rear wheel alignment, chain or belt tension
