free website stats program wider rear tire for my softtail flstc | Harley Davidson Forums
2000softtail
I want to add a wider rear tire and also lower it 1" front and rear. what is the widest tire I can run? and what lowering kit would you recomend?
I have a 2005 FXST that had a 150 tire on the rear stock. I was able to fit a 160 on the rear with enough clearance between the tire and belt. Beware of the tire rubbing inside the fender if the suspension squats alot ( launching off the line and/or a passenger on the back too). I had to adjust my suspension preload to keep it from rubbing. This did create a stiffer ride though.
i have a 99 fxstc with a 130 and there is no room. you may be able to get 1 size bigger but not enough to make a difference.. you need to check the clearance between the tire and belt.. the up side is the narrower tires handle WAY better.. imho
