White walls & spokes
Discussion in 'Wheels' started by exterminater, Dec 10, 2011.
  1. exterminater
    exterminater Member
    23
    Is there a best cleaner for white walls & what works best for cleaning brake dust off of wire (spoke) wheels?
    I used spray 9 (like fantastic) for the whites with a scrubbie pad or nylon brush and pledge on the wheels if you don't let them get too bad.
    [​IMG]
  3. HDDon
    5,543
    133
    229
    Doesn't get much whiter or brighter than that!
  4. SledDog
    SledDog Senior Member Staff Member Moderator
    2,120
    68
    88
    While I do not have white walls on my bikes, I do have them on a car. I use Bleche White. It cleans 'em right up with very little work. Just spray on a dry tire, let sit for 2 minutes, hit the tires with a washing sponge (or whatever) and rinse. It also takes off brake dust.
  5. 173ABN
    173ABN Active Member
    271
    I use Mr Clean magic eraser on the walls and Mr Glider pledge on the spokes.
  6. Bobbiegs
    Bobbiegs Member
    32
    If the white walls are really dirty, wet a rag with lacquer thinner and wipe the white part only. You do not want to overdo this as it does soften the surface of the white wall a bit. I do a small section at a time and immediately wipe it dry.
  7. gasbag
    gasbag Active Member
    356
    I wash my bike with Blue Coral auto wash.
    For the whitewalls I use Scotch-Brite heavy duty non-scratch scour pads and I dip them in the wash bucket to get all the suds. They work extremely well for me.
    For the spokes I use a long handled brush called a mag cleaner, used to clean auto rims. It has very soft 3 inch long bristles and it makes cleaning the spokes very easy to do.
    The mag cleaner also works well cleaning the engine and all the other little crevices dirt hides.
    [​IMG]
  8. Old Mike
    Old Mike Member
    Normally I use Mothers foaming wheel and tire cleaner on my laced wheels and white walls, but if the white walls are real dirty I like Westley's Bleache-Wite or I'll break out the Brillo pad.
  9. bikerdad
    bikerdad Junior Member
    506
    38
    10
    The real trick is not to let them get really dirty. I use Wesleys bleach White. Just spray it on and wipe with a clean soft sponge.
  10. NEWHD74FAN
    8,191
    98
    19
    Preclean with Gunk Engine Brite (do not leave on too long), rinse wheels and tires off then a small bit of Palmolive green dishwashing soap and long bristle brush. Whitewalls get the Wesley's Bleach White, and use raised white letter pen to touch up scuffs...! Spoke whees, lots of elbow grease, wax and plenty of white cotton tees...way too much trouble, so I am glad I have cast wheels with tubeless tires without white sidewalls now on my Sporty! Sorry...:s
