Where can I find a larger aftermarket gas tank?
Discussion in 'Oil' started by nesta95, Sep 29, 2006.
  1. nesta95
    nesta95 Member
    19
    hi,
    Anyone know where I can find a larger aftermarket fuel tank for my 2006 VRod.
    Nesta
  2. solanki
    solanki Member
    19
    Wow, I'd love to hear the answer to this one too. I hear rumours of a "Touring tank" which is an external add-on tank, but all the googling I can muster has failed to turn one up.
    Solanki
  3. johalber
    johalber Member
    32
    I guess you could use this (www.tourtank.com) but, it's not exactly inconspicuous is it?
    Johalber
  4. babella
    babella Member
    17
    The best only place I know is www.ricks-motorcycles.com Cost is 999 Euro which converts to about $1285. If it will help, maybe you could tell him Robert from Kaiserslautern sent you, maybe he will remember me and give you a deal. I haven't upgraded yet, but am going to get a quote.
  5. karthy
    karthy Member
    24
    The cost is 999 Euro which converts to about $1285. almost the cost to upgrade to a .07 that comes with a 5 gal tank plus other goodies
  6. diljera
    diljera Member
    19
    Hi,
    I can't imagine that my 2004 VRSCB plus 1300 bucks is going to get me a 2007 VRSCA. And what about all the guys with older V-rods?
    Does anyone know if it just drops in place of the original or are some mods required?
    For example, it's my understanding that Harley widened the frame to get the new 5 Gal tank in. I wonder how rick done it
    Diljera
  7. sopana
    sopana Member
    20
    I used Metzlers on a Deuce, rear worked good, front cupped badly on the edges, 10K miles was the life of both. Put Metzlers on the V-Rod, rear cupped badly on the edges and lasted 10K, front has no cupping and will probably go close to 15K. I've gone back to a Dunlop rear. Gave me 10K with no ugly wear pattern.
    I don't do enough twisties to wear out the sides and I avoid the rain if possible, which means I might miss 30 days of riding out of 365.
    For all you guys putting on bigger tires, why do you want to reduce the handling quality? 180 is optimum.
    Sopana
  8. solanki
    solanki Member
    19
    After talking with Rick, it does require some mods and you do have to remove your rear wheel, and swing arm and I believe move the plate in the back. takes
    about 4 hours.
    Solanki
  9. hdlover
    hdlover Member
    25
    I sent an email querying the price and fitting and I got a quoteand a Powerpoint of the fitting instructions. It's quite a job and a bit daunting. Getting a Harley mechanic to do it would be tempting but also add considerably to the cost. Also, 1300 bucks for a plastic tank seems a bit much! I guess we're paying for the development cost here, it looks like a pretty technical moulding.
    HDLover
  10. NEWHD74FAN
    8,191
    98
    19
    Personally plastic jug or any other type fake jugs for that matter, does not cut it...:newsmile100:
    Look at the Road King one that is rack mounted at the very bottom...
    http://www.sampson-sporttouring.com/fuel-cells.html
    Seriously, the VRSC came with a metal tank...either get one sculptured with modest 1 or 2 gals increase (6.6lbs/gal, high center of gravity) or add an auxilliary tank made for Iron Butt ralleys and such, they are more rugged and safer JMHO. :D
