not on the bearing itself, there is a spacer that goes from bearing to bearing and there is a void between spacer and rim itself.
The spacer seems to float between the bearings on the axle. Thanks![]()
I've not installed them at the moment, wheel is factory spoke wheel and new bearings from HD and spacer also, in between the spacer and rim only there is room to store a little bearing grease there and was wondering if I should apply grease in this area. I know the spacer does not rotate on axle when all is properly bolted down. I maybe thinking wrong about having grease floating around spacer. Thanks
Thanks, the next thing I need to get is a manual, the nickel compound is it sold at HD or some other supplier, Thanks again.
Thanks again, I'm new to this site, I seen also there is download manuals here, but you have to have 150 post before download, is this correct? Thanks
Yes you need to be an established member to get manuals that we have for download.
Contributor$: Max 1 file/24 hours.
Registered Member is Required: 150 posts and 150 days active membership.
The delay time for a Register Member for each download on each file is 604800 seconds (7 days), so members must wait one week after the first file finished downloading before downloading another one.
This is to help prevent the pirating of the manuals by delaying the downloads.
