wheel fitment ?
Discussion in 'Wheels' started by bigg1965, May 27, 2011.
  1. bigg1965
    bigg1965 New Member
    3
    wondering what other models wheels will fit on 97 sportster 1200 s was told softtail might but they arent shure ?
  2. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    Most Harley wheel hubs are the same thickness/width. The big difference in interchangeability is axle diameters have changed thru the years, and models.
    A good way to see what will fit your bike is to go to a site like J&P cycle, and select a wheel, then look at the "fitment" chart. Rim width is very important, you can't change that much as it changes the overall width of a tire a little. It can get confusing.
  3. fin_676
    5,775
    153
    284
    I have a 93 sportster so it has the same size wheels and axles as your bike and the rear wheel from my dyna or softail would fit as they are the same size wheel and axle
    front would be different as my 2 big bikes have wide glide front ends and as such will have a wider wheel on the front than the sportster
