Breeze3at
Experienced Member
Harley Davidson Wheel Alignment Made
Simple
In an ideal world the front and rear wheel should be:
1. Inline
2. Not offset from each other
3. In the same plane, i.e. if the front wheel is vertical, the back wheel
is also perfectly vertical.
In practice:
1. We can adjust
2. Hardly ever true, the rear wheel is usually offset 5 to 15mm but we
can live with it
3. We could have a problem, possibly a bent frame, but we can check
it.
Wheels that are not in alignment can cause handling problems,
excessive tire wear and damage the drive belt/chain and pulleys.
The H-D manual suggests that wheel alignment should be done using
straightedges.
The usually prescribed method is to support the bike, lay straight
edges along the rear wheel, and measure the gaps at the front. See
figure 1. To make things more difficult, the rear wheel can be offset up
to 15mm relative to the front (depending on model). So, the method
is.
1. Support the bike
2. Hold a couple of 2 meter long straight edges against the rear wheel
3. Turn the bars as near parallel as possible to the straight edges
4. Measure the gaps A,B, C & D
5. If A = C and B = D, then you've done it, if not, adjust rear wheel
and try again.
Not too easy, even supposing you've got 2-metre long straight edges,
and 3 meter long arms. In practice you need at least 2 people and the
method is really prone to error, 1 degree out in holding the
straightedge will give you an error of over an inch..
The Easy, Accurate Way:
Materials Needed:
1. Fishing line, about 5 or 6 meters (or strong thread)
2. A nut or similar to use as a weight
3. A piece of strong wire bent into an 'S' shape making a hook about
2” long (coat hanger wire is perfect)
4. A long rubber band (about 6” is ideal) or 2 shorter joined together
1) Check the Tires:
Check that tire pressures are correct, Ensure that the tires are fitted
true to the rime. Usually there is a line around the tire wall. This must
be concentric to the wheel rim.
2) Prop the Bike Vertically Use a lift:
if you've got one, otherwise maneuver onto blocks. Check for vertical
alignment using a piece of fishing line with the nut tied on the end to
act as a plumb line. See figure 2.Shim the blocks or lift until the line
just touches the tire at the top and bottom edges of the tire. If you've
got patient, strong friends they can brace themselves and hold the
bike steady instead of using blocks. Don't worry if it's not exactly
vertical, ‘nearly’ is good enough.
3) Attach the fishing line:
Attach one end off the remaining fishing line to your hook. String your
line around the back wheel, down the side, around the front tire and
down the other side. Trim to length, tie to rubber band and clip the
hook attached to the first end to the rubber band. See figures 3a, 3b.
Ideally, the line should be as far up the wheels as possible. Make sure
that the line touches only the tires! If it catches on foot pegs or
exhaust, you will need to move it up and down until it just touches the
tires. For simplicity, all the illustrations show that the rear wheel
without offset relative to the front. In practice it will be, but the
amount is usually small enough to make no difference to this
alignment procedure. If you want to be sure, read the last section
which deals with large rear wheel offsets.
4) Test the Alignment:
Slowly turn the bars clockwise. Keep checking the line. Hopefully, you
should be able to get the line to touch
Touch the tires at al four points A,B,C and D (see figure 4). Check by
inserting a thin piece of paper at points B & C (don’t worry if either B
or C don’t touch, but if A or D don't, then boy do you have a problem),
a cigarette paper is ideal. If the line is touching, the paper should be
held in place by tension only.
Repeat, this time turning the bars anti-clockwise. If you're really lucky,
the line will touch the tires at E,F,G,H (see figure 5). If this is the case,
then your wheels are aligned.
Now look at figure 6. (Above) This shows an example of the rear
wheel misaligned towards the left. If you move the bars to the right,
you can still get the line to touch at 4 points (fig 7a). But see what
happens when we turn the bars to the left (fig 7b).
5 Adjust the Alignment:
We have seen above how a rear wheel skewed to the left will not allow
the string to touch the right rear tire (point ‘G’ in figure 5). The
converse is also true; a skew to the right and you will not be able to
touch the left rear tire (point ‘C’ in figure 4). So to correct our left
skew above, remove the split pin, loosen the axle nut and slacken off
the adjuster on the right side. Tap the type until it settles against the
adjusters. Tighten the axle nut and repeat from section 4 until in line.
You will note that I specified adjusting the wheel by slackening the relevant
adjuster. You may be tempted to tighten the adjuster on the other side of
the wheel which will have the same effect, won’t it? Don’t do it! It will move
the wheel alignment but it will also apply more tension to the drive belt or
chain, possibly causing damage!
6 Check your belt/Chain tension
After you’ve got everything nicely lined up, turn the rear wheel and
feel the belt/chain tension as it moves round. Leave the wheel in the
position where the tension is highest. Sit someone on the bike (you
may need to remove the lift or blocks for safety). The belt should
move about 10 - 13mm if you put about 4.5Kg of pressure on it
(Chains should have about 25mm of movement). You may need to
remove the belt guard to judge this. If the belt/chain is slack, and it
probably will be, loosen the axle nut and turn each adjuster the same
amount until you get the tension right. Tighten axle nut (60ft lb
torque) and recheck tension. If correct, then you need to check your
wheel alignment again just to make sure it hasn’t moved.
7 Reinstall Split Pin removed in step 5:
That’s it, all aligned. Although it might be a good idea to check that
you tightened everything properly before you go out on it.
Appendix
*A Note on Wheel Offset:
Modern Harley-Davidsons have the rear wheel offset somewhere
between 8 and 13mm. (See fig 8)
Throughout this document, I have assumed in this document that the
offset is less than half the difference in width between the rear and
front tires (it usually is).
Where:
Z = offset
r = width of rear tire
f = width of front tire
If your wheel offset falls outside these parameters, e.g. custom frames
with large offsets, then you will need to modify the procedure. The
easiest way to do this is shown in figure 9.
The batons on the side of the tire effectively increase the tire width
Special Thanks To Wide!
`ÉàÉÜvçvÄxÅxàtÄAvÉÅ \ÇvA
5490 S.W. 42nd St.
Davie, FL 33314
1-866-899-5962 Toll free
1-954-449-6173 Local
Simple
1. Inline
In practice:
1. We can adjust
can live with it
it.
straightedges.
is.
1. Support the bike
and try again.
Materials Needed:
1) Check the Tires:
Appendix
Where:
Z = offset
5490 S.W. 42nd St.
Davie, FL 33314
