Rich Brown
Why is wet sumping an issue with softails and what is my fix ,new high output oil pump or somthing simpler . My issue is with oil spitting out the vent line in my carb and hence all over the bike .
MY question to you is "is the oil draining into the sump??? where is the oil level Before you start engine from cold?.... and also HOT?Why is wet sumping an issue with softails and what is my fix ,new high output oil pump or somthing simpler . My issue is with oil spitting out the vent line in my carb and hence all over the bike .
