revok1200
06' RG, when I was putting the front wheel back on after doing some work, I was following the manuals directions and came to the spot that said to put a 7/16" drill bit through the axle, pull the fork snug to the bit and tighten down the nuts on the bottom of the leg. Okay, I'm good with that.
WHY? This left some space between the spacers and the leg. Is the space supposed to be there to keep things from binding? I figured one of you will know, and I always like to learn something new.
I also need to mention I have changed out my wheels for a set of 08' cast wheels and now have a 36mm axle and not a 1".
Does the 08' manual call for the same procedure as the 06', using the bit to create some space.
Okay, that was 3 questions.
Thanks in advance
Thanks in advance
