vance and hines exhaust
Discussion in 'General Harley Davidson Topic' started by sportyXL06, Jan 28, 2009.
  1. sportyXL06
    sportyXL06 Member
    60
    this is for glider thank you for the advice on the carb the other day But I am having trouble finding the #4 washer for the carburator
    upgrade for my 06 sportster 1200 I ordered the jet for the carb. I did find
    a # 2 fiber washer but I do not know if that will work all I can find in my area is a # 6 are there any other options for me or will a # 6 work?
    Glad it worked out for you. The #4 washers fit the needle just right. Go to a home depot etc and look at the washers in the pop rivet section. You'll find they are a bit thicker thou and you would only need one of them.:s
    The right size fiber washer will work too.
