Valve Caps
Discussion in 'Wheels' started by HDDon, Aug 31, 2011.
  1. HDDon
    5,562
    133
    236
    I just read an interesting article on schrader valves and valve caps. I'm sure that everyone checks their air pressure and makes sure that the valve caps are on tight before they ride. But have you ever had a valve cap go missing and took off for your ride without it? Some of us have custom valve caps that somehow go missing after a lunch stop. The article was interesting in that not only does the cap keep things out of the schrader it also keeps air in that might escape. It seems that under spirited (read high speed) riding the centrificle force can and does compress the spring inside the schrader and without the cap you can have a very flat tire in a short period of time. How about checking those caps and make sure they are tight. HDDon
  2. dbmg
    dbmg Guest
    Thanks for pointing that out HDDon. I completely agree and am very diligent on all my vehicles including the kids bikes...:) Very Important.
  3. glider
    50
    You ride kids bikes too ? :lolrolling
  4. HDDon
    5,562
    133
    236
    I think he was the guy at the XGames that did the double back flip!!!:small3d018::small3d018:
  5. fin_676
    5,789
    153
    287
    I always keep the valve caps from old tubes and valve stems when they are replaced so i have a few laying around i like the ones with the wee core tool on the end in case i need to change the core when I'm on the road
  6. R_W_B
    R_W_B Senior Member
    2,425
    23
    I like those kind to Brian, come in handy sometimes. Never can tell when you are gonna have a wee problem.
  7. dbmg
    dbmg Guest
    On a flat road I can ride the 3 hp minibike and the electric sport bike. My kids thinks its funny, like when the clown at the circus rides a mini bike....:lolrolling
  8. Mavagrand
    Mavagrand Senior Member
    1,250
    12
    Good info. I've noticed the caps I buy from AutoZone don't last as long as they used to before they crack and fall off!
  9. TXMikey
    TXMikey Junior Member
    477
    Excellent advise HDDon. Not long ago, I went to check the air pressure in my front tire. When I unscrewed the valve cap, air started leaking from the tire because the valve stem had come loose. If I didn't have the valve cap, I would have had a very flat tire.
  10. Iceman24
    Iceman24 Well-Known Member
    3,266
    23
    Funny how those "custom" stems seem to disappear during stops (i.e. dice, skull, HD logo, etc.) - access is too easy. Another reason I stick w/the good old standard valve stems...one of the few items I won't upgrade. Like to keep a few in the bag - in case they're needed.
