V&H Dresser Duals question
Discussion in 'General Harley Davidson Topic' started by altoona, Nov 4, 2013.
  1. altoona
    altoona Member
    7
    I have a 2013 Limited and I'm looking at installing the V&H Dresser Duals with the Screaming Eagle air cleaner and stock mufflers.
    Any thought on this combination? I'm just trying to lower the heat on my right leg. :33:
  2. Harley38
    Harley38 Active Member
    138
    I have V&H Dresser Duals, SE HI-Flow A/C and Rush slip-ons on my 11' FLHTK and really like them. Good look and sound good. They will be cooler on the right leg than the stock exhaust with the cat.
    Also, with those changes look into a fuel management device to richen up the A/F ratio like TFI, SEPST, etc.
    Hope that helps.
  3. Dr. Dolittle
    6,404
    118
    29
  4. glazier
    glazier Junior Member
    940
    7
    I've got the same bike. I removed the cats from the headers and put on Wild Pig slip ons w/ 2" baffles. Much better sound, not as restrictive as stock, and very reasonable price. Reduced the heat a lot, but in the summers in Dallas, it's gonna get hot anyway. Haven't done the hi flow a/c yet, or a tuner, but thats this winters project. That should help for next summer. If you put on a Stage I a/c, you're gonna have to add more fuel or it will lean it out and make it run hotter.
  5. altoona
    altoona Member
    7
    Thanks for the info. I was also thinking going with the V & H Monster Ovals but was concerned it might get to loud for my significant other on the back. :eam
  6. Wlindsey
    Wlindsey Member
    I'm running V&H Wide Ovals on mine and I love them. Not too loud but a really nice rumble. Also running the Screamin Eagle stage 1with the HD heat deflectors and my right leg still gets pretty warm riding in 100 deg temps.
  7. Trek
    Trek Junior Member
    575
    I have the Monster Ovals on my 09 ultra and it has a nice deep rumble. I can hear the radio at highway speeds very easily and only about half way up at the most. My wife is fine with sound also. Just my 2 bits. I think they look good with the side bags too. Good luck deciding.
  8. altoona
    altoona Member
    7
    Thanks for all the input. I decided to go with the Monster Ovals, Dresser Duals, and Screaming Eagle air cleaner. Currently on order.
    Next question can I install the Duals and Ovals and not have to re-tune?
    I know I will need to do a re-tune after the Air cleaner is installed just not sure about if I just do the mufflers and Duals first to see how it runs then install the stage 1 air cleaner and re-tune.
  9. Jack Klarich
    While these beasts run lean to begin with, you can usually get away with changing exhaust only but adding fuel will be a big plus in power and cooling
  10. RibEye
    RibEye Junior Member
    992
    60
    I went from Hooker Tuned-Flow to Monster Ovals. Sometimes I miss the super-loud bark of the Hookers. However, after a day in the saddle, the Hookers did seem to get a bit obnoxious, and her-Heidiness rode with ear plugs. I switched to the Monster Ovals, and the rumble dropped to a nice deep tone, with the harsh leading edge was eliminated. Momma needs no earplugs. The scooter breathes pretty much as well as she did with the Hookers.
    Enjoy,
    Rich P
