Unequal handle bars turning/steering
Discussion in 'Sportster Models' started by Ken 1965, Oct 12, 2012.
  1. Ken 1965
    Ken 1965 New Member
    4
    The handle bars on the Sportster I have rotate further (turning) to the left than the right; in fact the left turn light contacts the fuel tank prior to hitting the steering stop. Rotating the handle bars to the right is OK, i.e. contact is made with the steering stop before the right turn light hits the tank. Both steering stops look OK (not damaged). Any ideas? Thanks again for your help.
    Ken
  2. R_W_B
    R_W_B Senior Member
    2,425
    23
    Make sure both turn lights are adjusted the same, one might have slipped down more.
    Make sure you handlebars are not slightly bent on one side.
  3. chappy99
    chappy99 Member
    10
    I seen you post this before,if you cannot see anything wrong yourself.
    You should take your bike to someone (indy) or (dealer) and have it checked
    out,i know this is not much help but i'am thinking of your safety.
    Their is just so many things it could be.
  4. mouthful
    mouthful Active Member
    155
    Has your bike ever been tipped over on its side? Things tend to get bent.
  5. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    Re: Front wheel rotates too far to the left
    Ken,
    Measure from the center out... Look for any abnormalities. Not remembering the lighting on your bike...
    IF the stop is Not where it should be.... A spot Can be welded on that frame Knob,(IF that is the way it is set up)... I have heard of some drill and tap for a short headed screw there also to take up some space so it doesn't turn as far. I had a 97 FXDS but don't remember it for sight in thinking with out a picture....
    I doubt IF the turning geometry is More to one side...
    I had a friends bike that did about the same thing,,,,It was in the handle bars and the light not the same as the other side..
    MEASURE first...
  6. Jack Klarich
    Are the steering stops in place and has this bike ever been wrecked or tipped over? Are the handle bars centered in the risers?
  7. NEWHD74FAN
    8,191
    98
    19
    What Bubbie says makes sense for two reasons...many adjust the handlebars to a more comfortable position to fit, the other being the hand control cluster on either side as well as the signal mount angle can usually be adjusted symetrical, so they do not hit anything.
    Personally I don't like them mounted there, but it is the widest part of the bike to meet DOT regulations here in the US.
  8. Ken 1965
    Ken 1965 New Member
    4
    Thanks Jack. I suspect the bike may have been 'dumped'.
    Ken
    I think it may have been tipped over. Thanks,
    Ken
    Your concern is appreciated. Thanks,
    Ken
  9. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    Ken; When you are driving straight down the road, everything on the front end
    should look straight, equal distance from an imaginary line from gas cap to center of front tire. If the front has a slight tweek to the left or right, you can put the tire against a post (don't damage fender) and bump it a few times to get it centered. Any more than slightly tweeked should be checked by a reputable mechanic for safety reasons. Might be a good idea to have it checked by a mechanic anyhow.
  10. BUBBIE
    4,974
    125
    This was questioned in another thread Ken started.... It answered there and so maybe the Tank or another moderator will merge the two post mentioning the "Bars question"
    I have a link below to it OR they may Not.:D
    Oil light stays on after oil change - Page 2 - Harley Davidson Community
