free website stats program turn signal problem | Harley Davidson Forums
turn signal problem
Wondering it anyone would know,
I have fitted a set of turnsignals to my 1996 softail, the problem am getting is , the right side flashes off and on , as it should do but the left side just gose on but dose not flash, Am thinking there is summit wrong with turn signal module, but not 100% sure thats whats wrong, as these parts are exspencive was wondering if anyboady could confirm my thoughts thanks
You need to give some more info to get the correct answer. Are the signals LED or regular? Did you check to be sure all the bulbs are good and working properly and inserted into the sockets correctly, the proper size and type of bulbs?
