scrinch
I have been dealing with a issue on my HD 2001 Road King and Liberty SC this summer that just seems to keep on.
The hack has it's own right directional lights plus the rear brake light also acts as a directional. I also have a headlight modulator installed.
Sometimes the directional signal on the left side would flash 4 times regular...then 4 times fast then cancel. The right would flash at the regular rate then cancel after 8 flashes. This did not happen all the time. If I put my directionals on late they would often respond correctly cancelling after the turn. If am stopped and then put them on they will also sometimes respond correctly but often the left signal will flash 4 slow 4 fast and then continue fast until I turn.
I read that the Badlands load equalizer lll would take care of problems like this so I ordered one and installed it according to directions. It worked for one time and then went back to the previous cycle of 4 long 4 short and cancel...I called the Badlands Company tech support and was told to disable the right rear directional on the bike. I was good with that because I always felt it might be confusing to cars behind to have both a directional on the bike and hack. No help.... So I ground off the terminal on the bike's right front directional bulb so only the running light would work. Now the right light is going 4 long 4 short and canceling. Man this is getting irritating and I also think it is dangerous not to have the directionals go for more than 8 cycles before they cancel.
I have also pulled the main fuses more times than I can count to reset the computer modules.
Other than doing hand signals does anyone have any suggestions on where to go from here.
