turn signal issue
Discussion in 'Sportster Models' started by flstn, Apr 16, 2011.
  1. flstn
    flstn New Member
    i have a 2000 xl1200c the emergency flashers work but individual turn signals light when button is pushed but wont flash.
  2. Jack Klarich
  3. fin_676
    5,779
    153
    285
    That would normally be caused by insufficient current draw through the circuit it often happens if the bulbs are changed by lower wattage bulbs like led
    if you do need to run low watt bulbs then you will need a load equaliser to increase the load on the circuit
  4. flstn
    flstn New Member
    This bike is running incandesent bulbs even wired up 1057 bulbs to make sure. Same thing hazards will flash when activated and individual turn signal will light when button is pushed but wont flash. Have also replaced the tsm. Really need help with this one.
  5. glider
