SeaBass67
99 FLHRCI
I recently installed the kuryakyn led bullets on the front and incandescent bullets on the rear. I have the load equalizer plugged in to the kuryakyn harness adapter on the harness under the seat.
Now:
L/R signal will flash fine.
R/R signal has power at the board and light socket but the bulb does not illuminate (bulb tested good) and there is no flash when I hook up the test light at the board.
L/F led bullet/signal has power in the wires (past my solder connection) and flash but the led's do not illuminate or flash.
R/F led bullet/signal has power in the wires (past my solder connection) but no flash (even at the harness connection) but the led's do not illuminate.
Driving lights work.
Headlight Hi/Low beams work.
I removed the harness adapter/load equalizer and the left rear signal would just illuminate and produce no flash.
So this leads me to believe there is a ground issue(?)
Where is the location of the main ground for the signals?
Thank you in advance for any insight you can provide!
Bueller? Bueller?
Now:
Bueller? Bueller?
