Hey Glider. Thanks. I did look in the owners manual, and there was no cross reference in the 2005 Eletra Glide manual. It only have the HD part number.
The reason I am asking is for some strange reason my left turn signal is acting up. I had put on the Harley Davidson Turn and Brake harness so I would have the rear running lights and brake lights. I also got the red lenses and put them on. Well just out of the blue, I noticed that the left turn signal was dim but lite. I said humm. Whats going on here. So when I cranked the bike it went away. So I didn't think anymore about it. Well the other day it did the samething. Left turn signal of the dash was dimly lite.
Well when I turn on the bike it was still lite. I press the left turn signal switch the lite would do a nomal flash, then a rapid flashing, and when I press the hand break or the foot brake, the left turn signal would start flashing also. I thought ok it must be the turn and brake harness I put on, and took it off.
Well when I took it off, it did the samething. So I cleaned all the base of the bulbs and still did the samething. Well now I am really starting to look into what is going on here. So when I turn on the left turn signal I noticed that the front one, when it flashed it would go completely out and back on. It was like the other filement in side was not staying light. So I replaced the bulb and it started working ok. I said that was it. The bulb was bad.
Ok this morning I fired it up for work, and bang there it is again doing the samething. So now I was thinking that maybe I put the wrong size bulb in there. I took it out this morning when I got to work and look at the number and it was a 1157 bulb. Could not see any filiment damage, so I put it back and now its working ok. Does any of this make sense? I am at a loss here on what just might be going on. Any suggestions?
Thanks
