free website stats program true trac. | Harley Davidson Forums
true trac.
fattyboy
2001 roadking around 75-80 bike go's into to a big wobble, still has dunlop's on , will the true trac help.
get ride of the dunlops and any stablizer will help .. i have the rev tech helped a ton .. getting ride of the junk dunlops helped even more
Checked tire balance and steering pre-load, and wheel bearings? I had a wobble, fortunately at 35 mph, and my steering pre-load was fine by the book. After checking alignment and balancing the wheels, the wobble remained. I tightened the steering bearings, and all is wonderful again.
Might also check spokes for braekage and tightness. I had a couple of them loose and had a wobble at 55mph.
True Track works great. When the stock Dunlops wear out put on the Elite3 which are amazing improvement over stock Dunlops.
Thought of these later- The front engine mount and the lower link rubber parts might be deteriorated and softened from years of oil changes, at least worth a look.
