Trouble removing those reflectors?
Discussion in 'Members Tips For Easy Maintenance' started by Bossie, Oct 22, 2006.
  1. Bossie
    Bossie Member
    21
    I was having a really rough time and my mom actually came up with this little trick, not sure if she read it somewhere or if she just smart, but here goes.
    Slice the reflctor off using a strand of dental floss, holding kind of like you do your teeth and gently sawing away. Then soak in W-D-40, it will come clean as a whistle.
  2. flybikes
    flybikes Member
    53
    Wow dental floss, you just never know what might come in handy, huh? I wonder who first thought this one up, it always amazes me to see how clever people really are!!
  3. medsed
    medsed Member
    I have heard of floss being used to cut brotherh, slice cake or cheesecake and as replacement thread for buttons that fall off a lot, but I have to say this is a new one for me! I think it is great to see these common items put to interesting uses!
  4. qman
    qman New Member
    4
    You can also use fishing line. Works real good.
  5. oct1949
    oct1949 Member
    23
    hair dryer worked for me, then WD-40
  6. krikket
    krikket Active Member
    327
    So that's what dental floss is for!!!!
  7. JamesRClark
    JamesRClark Member
    8
    Great idea.
  8. airforceacop
    airforceacop Active Member
    105
    it helps slide the between the relector and the frame, works real good too! then wd 40 to remove the left over adheisive!
  9. gator508
    gator508 Experienced Member
    5,371
    333
    2,732
    +1 on WD40, you could spray some in a cup and apply to reflector before trying to remove it, should make it much easier.
  10. Iceman24
    Iceman24 Well-Known Member
    3,268
    25
    Another option...I used my wife's heat gun (crafting) and "carefully" ran it up/down reflector(s). Once I got an edge off - kept applying heat & slowly lifted/pulled reflector off. Left little/no mess and then goo-gone got the rest.
