trouble code
Discussion in 'Electrical' started by dynalarry, Jan 9, 2008.
  1. dynalarry
    dynalarry Member
    9
    i have a 2006 fxdci and am getting trouble code po113-iat sensor voltage open/high efi. i have a screaming eagle intake and cycle shack slip on mufflers and the efi was remapped by a harley dealership.:p
    56
    I moved your question here because the self help forum is not for starting a new thread. Your question should be asked in the proper forum instead.
    That refers to the intake air temp sensor. Quite possible the sensor is bad or the wiring has a problem somewhere and should be checked out by a mechanic familiar with the system.
  3. dynalarry
    dynalarry Member
    9
    glider, thanks for the info. i'm new to the site and don't know what i'm doing. thanks again.
  4. glider
    56
    No problem. If you can't find your post, click on your name on the bottom of the home page and it will take you to your profile. From there you can find all your posts.
