Romain
Hi!
I have a 2007 Sportster 1200 XLC.
I have to change the neutral switch and unfortunately, to access it, I have to remove the transmission sprocket.
To do this, I have to use a transmission sprocket holding tool and, as I’m not going to do this operation on a regular basis, I wonder whether there is an alternative to using the specialised (rather expensive) tool without damaging the sprocket…
Thank you for your suggestions.
