Trailering your bike
Discussion in 'Touring Models' started by KCBROWN, Aug 30, 2009.
  1. KCBROWN
    KCBROWN New Member
    4
    Where should you attach to the bike the front and rear tie down straps to a 09 street glide when trailering? Should the bike be left on its stand? In neutral or in gear?
  2. kemo
    kemo R.I.P
    1,690
    5
    I attach soft straps on the front down tubes above the crash bar and tie the rear at the floor boards.
  3. STEVE07
    4,123
    68
  4. vtbikers
    vtbikers Active Member
    174
    I do the same as the first post and it work good
  5. Mavagrand
    Mavagrand Senior Member
    1,250
    12
    make sure your trailer has an enclosed front end.sand, rocks and debris thrown up by your truck can do a number on your bikes paint.
  6. Rewind
    Rewind Active Member
    251
    And remember to not pull the front end all the way down, you need some travel in the front forks. If you pull the front end all the way down you could blow the fork seals.
  7. Aces Full
    Aces Full Member
    21
    This is exactly how I tie down my Ultra. I use a Baxley trailer, which is the easiest to load I've ever used, and 4 soft straps, and 4 ratchet tie downs. Whatever you do, avoid tying down to the handlebars.
