tps setting
Discussion in 'TFI Settings' started by fattyboy, Apr 10, 2012.
  1. fattyboy
    fattyboy Active Member
    105
    I have a 1999 road king It has the m&m fuel inj. does anybody no how to set the tps and what should the reading be useing a dvom.
  2. dbmg
    dbmg Guest
  3. Hoople
    Hoople Account Removed
    7,198
    34
    This may also help. They talk about using a breakout box, but instead just use a DVM and backprobe the TPS connector (gray/violet wire) or go directly to pin 30 of the ECM.
    I have never worked on a MM induction body, but it sounds like your adjusting the rest position set screw for the butterfly stop so just make sure the idle speed control actuator is not choking your adjustment off early...
    That's how I read into it.
