torque of exhaust flang nuts
Discussion in 'Touring Models' started by chief9042, Jul 14, 2010.
  1. chief9042
    chief9042 Member
    15
    Can anyone tell me the proper torque for the exhaust flange nuts on a 103ci FLHTK? Thanks
  2. Redfish-Joe
    Redfish-Joe Senior Member
    2,307
    10
    This is for my 96 but should be the same
    Tighten top nut to 9 - 18 in-lbs
    tighten bottom nut to 100 - 120 in-lbs
    Re-tighten top nut to 100 - 120 in-lbs
    Repeat on the rear exhaust
  3. ultrat
    ultrat Senior Member Contributor
    1,315
    shure glad i did not answer that one, i was not close....
  4. dcfatboy
    dcfatboy Active Member
    153
    I always check the torque values after everything is bolted up too.
    (On my 2004 Ultra, you start the torquing sequence on the top or bottom of the front flange and the OTHER ORDER on the rear flange.)
