I have a '99 Harley Fatboy that has a lowering kit (2-3"). At the end of last year my wife and I took a short road trip together. She is only 140 Lbs and I am 180 lbs. When ever we would hit a small bump, we noticed that my ride "bottomed out" or was rubbing on what we thought was the fender. In looking closer, I noticed that the outside of the tire itself seemed to have some uncommon wear apparently form rubbing on the belt. I inspected this and saw that the tire when no rider was on, was only about 1/2" away from the belt. I adjusted my air pressure to accommodate the extra weight (40 psi), to no avail. I thought that my shocks were going bad as they are adjusted full out.
In looking at this closer, I noted the tire size that is on there now. It is a 140-90 B16 m/c 77H. In looking at the PDF that another member of this forum posted, I see that the stock tire for that make and model is a 130-90-16.
Is it possible that the difference between a 130 and a 140 is drastic enough to cause this tire to rub? I am now wondering if the "rubbing sound" or bottoming out is also caused by this difference in tire size? I would welcome comments from any one with knowledge on this subject! Or any comments at all. It would save me a lot of guess work and unnecessary parts replacements. I don't want to have to fork out $300.00 for a new set of shocks if the ones I have are fine. Thanks in advance for any input!
DJ Culver
DJ Culver
