Posted by Dobeck in reference to which plug from the TFI unit gets plugged into which plug from the bikes harness...
It does NOT matter which pair of injector connectors plugs into the front versus the back, but we do recommend for the 2010+ HD Touring models to plug the connectors with a double pinned red wire and a yellow wire to go to the front cylinder.
Why? These new Harleys have a heat reduction mode where if the engine temperature gets too high they actually shut off the rear cylinder in an effort to reduce the heat. This rarely happens with our unit installed because by adding more fuel at idle we are already keeping the engine temps lower. If this did occur though and our channel 1 connectors (red/yellow wires) was plugged into the rear cylinder then our controller would also shut off. We only power our unit through channel 1.
