TFI install question
Discussion in 'Softail Models' started by BOWHIKER, Aug 10, 2010.
  1. BOWHIKER
    BOWHIKER Junior Member
    434
    5
    When installing the Doebeck TFI do you leave the O2 sensors in or remove and plug the bung hole . If you leave them in do you wrap the unplugged end some how as to protect from the elements ? If taking them out what is the pipe thread size for the plug to replace the O2 sensor . Matt at doebeck said I could just leave the sensors in and coil the wire up . What do you think ?
  2. R. Lewis
    2,183
    5
    Might want to listen to the man since it's his product line!
  3. Charlies Harley
    Charlies Harley Active Member
    303
    You can get special plugs, not pipe or bolt thread. Plugged off proper looks cleaner.
  4. BUBBIE
    BUBBIE Well-Known Member
    4,974
    125
    I like to tape original wires together,,,,, back to the plug the TFI comes with...
    That way they Look hooked up and are ready to re-hook up if I want to....
  5. Hoople
    Hoople Account Removed
    7,198
    34
    The thread is 18mm X 1.5
    Your going to get a broad spectrum of answers on whether to remove them or not. There all correct answers,,, but for me, if I had the proper socket I would remove them. If you don't have the right tool, just leave them in there.
  6. Redfish-Joe
    Redfish-Joe Senior Member
    2,307
    10
    I plugged the resistors into the plug going to the O2 sensors and used the tie wraps to tuck the wires from the sensors up neat and tight.
  7. Breeze3at
    Breeze3at Well-Known Member
    4,921
    224
    It seems like my TFI came with plugs to seal the 02 sensor plugs. I just ran my wires to a unseen area and tie wrapped 'em out of the way.
  8. wilks3
    wilks3 Junior Member
    623
    You wanna have some fun???
    Screw in 2(anybrand)18mm spark plugs with spark plug wires disappearing up into frame.
    Sit back and enjoy.
    wilks3
  9. wilks3
    623
