TC96 in an evo frame
Discussion in 'Custom Models' started by jimduncan, Nov 8, 2011.
  1. jimduncan
    jimduncan New Member
    Is there anyone who has done this or knows of someone who's installed a TC96A in a rigid frame made for the evo?
  2. HDDon
    5,562
    133
    236
    If you can measure and weld anything is doable. I put a 327ci in an Austin Healey Sprite. That being said being doable and being practicle are two different things.
  3. SledDog
    SledDog Senior Member Staff Member Moderator
    2,121
    68
    88
    WOW! Did you have to beef up the suspension on the Sprite?
  4. tourbox
    tourbox Senior Member
    1,902
    173
    A couple of years back I built a TC95A out of TC88A parts. I put that in a Paucho HT frame that was set up for a Pan,Shovel or EVO motor. You need an adapter plate for the rear mtr. mount set up. If you have to buy new cases then S&S has the cases already set up Evo style mounting, for the
    TC88A. The frame I have has a 40 deg. rake & 1 1/4/ stretch in the down tubes.It started out as a Shovel, 4 Speed. Went to the 95 and a 5 Spd.
    Well now it's back to an Evo & 5 speed. I like the Evo design better. Still
    ride when possible.
  5. HDDon
    5,562
    133
    236
    Frame, motor mounts, springs. Jaguar rear end, axels and hubs. Young and dumb and way to much time on my hands, and Dads' garage full of tools.
  6. jimduncan
    Thanks for the input, I have the engineering all done, it took 3 different places; one to cut a new motor mount, another to mill a space for the oil gasket, and a third to cut new splines in the compensator sprocket. The marrage plate for the inner primary I made up myself.
    What I'm most looking for is help on the EFI, but today I ordered the ECM and wire harness from Harley, guess I'll work it out myself!
    Of course now Vulcan engineering is making an adapter plate for the 96; too late for me though. Also, I think my new rear mount is stronger.
