This subject has already been discussed here, I know, but besides replacing the stock silent chain and spring tentioners or going to gear drive, there is a third option. Andrews sells a 07 roller chain convertion to fit TC88. Actually Andrews only sells the cam shafts with the larger outboard journals. You can then buy the 07 Cam support plate, roller chains, tentioners, and oil pump from HD dealer. Then you will have upgrades of the 06 Danas and 07 96TC. The roller chain has been "smoothed" on the side that contacts the tentioner and the tentioners are hydraulic. *The early 99 TC88 require that an oil hole be plugged on the new cam support plate. If you go to andrew product display case phase at andrewproducts.com
they can e-mail you the installation instructions with lots of pictures. Note: When asking for the parts at the HD parts counter you should tell them that it for a (any) 07 Bike. If you try to explain that you want to retro fit 07 parts to an TC88 they will tell you it can't be done because the TC88 and TC96 have different part numbers. Ofcourse they do, but they will fit.
Mac2000HS
Mac2000HS
