tappet screen
Discussion in 'Softail Models' started by carz, Oct 8, 2009.
  1. carz
    carz Member
    Any ideas where the tappet screen on my 89 fxsts would be i have a feeling either thats clogged or something else is cause i checked my oil pan and the oil was almost spilling out.. so i drained the oil and only about 2 1/2 qts came out???? so im guessing th return is working but theres either a cloged screen or a clogged hose..
  2. R. Lewis
    2,183
    5
    how much oil should you have in it? I have a 87 FXRC and about 2 1/2 is all it needs.
  3. springer03
    springer03 Active Member
    141
    sound like he has drained all his oil! Check the hose first.
  4. glider
    50
  5. Caper
    Caper Active Member
    236
  6. carz
    carz Member
    Qsuick question guys, with cars a while ago we used to put a cup or pint of karoseen in with some regular oil and run it for a min or so then drain the oil and put fresh in. to remove the sludge and from my passed exp with cars that worked really well , cleaned it out and bam problem solved... any one ever hearded of this or done this with a bike??
  7. glider
    50
    No kero, use marvel mystery oil.
  8. Caper
    Caper Active Member
    236
    SeaFoam is good too
  9. carz
    carz Member
    Ok well i had an 85 kawasaki ltd 700 and put the marval in the oil and the gas and i had nothing but problems... any differance between the two?? does anyone know anything about sea foam??? IS IT SAFE WHATS THE PROCEDUARE??
    :newsmile082:
  10. glider
    50
