Tach, work's, don't work, work, don't work...?
Discussion in 'Electrical' started by HACKSKULL, Sep 12, 2014.
  1. HACKSKULL
    HACKSKULL Member
    8
    :wallWhat would make the TACH work on and off...?
  2. Bodeen
    4,643
    73
    221
    Bad power connection or a bad signal connection.
  3. dbmg
    dbmg Guest
    Checking power sources are 1st step. Then if bike is modified tracing out circuits is next. Is this concern just starting or has it started after latest mod?
  4. 03HD883R
    03HD883R Active Member
    167
    Easiest thing to do is trace the circuits. I like to use a multimeter on continuity, and trace them out that way. While it's on continuity, wiggle the wires around and see what occurs. If you lose continuity, then there's a break.
    Make sure to test for voltage before doing continuity, or you'll pop the fuse on the meter.
    The tach reading is a pulsed reading from the coil.
  5. HACKSKULL
    HACKSKULL Member
    8
    It has acted this way ever since I got the Bike...I'll play with it & let you know...I Hopefully will be getting another Dash, one that has the FUEL Guage in it!:)
  6. mikeymanbike
    mikeymanbike Member
    18
    Sounds like a union labor contract issue!! Lean toward power,(on , off ,on . off). The plug may have a wear fit, plugged ,but intermitting power. vibration on and off. Ground wire , also.. Wire harnesses can move , over time....
  7. HACKSKULL
    HACKSKULL Member
    8
    Well, I just bought a Tach from CL & the guy had it on his Bike & guarentee's that it work's Great! I'll let ya know when I hook it up...Now I'll have a FUEL Guage too!:tounge
